Discussion topic: Connections
This message was authored by: 1c2b
Connections
Our broadband checker says everything is fine but we cannot connect any devices or watch any apps that require internet connections through the sky box
Re: Connections
Hi @1c2b
Avatar for 1c2b
Re: Connections
Hello thank you for your response we are on sky hub which does not have the WPS button on it?
Re: Connections
Hi @1c2b
All hubs have WPS button
Avatar for 1c2b
Re: Connections
Found it thank you
it worked for around 20 seconds the connection to the internet had a tick but then back to cross and as I stand here watching it it flashes tick and cross. We have had 4 engineer vists and new router and line in to the house. The last engineer was helpful and also visited the box outside and changed ports. Since then the internet says it's fine but we cannot connect anything phones computer (even with hardwire) and cannot watch Netflix or any other app through the sky box
