Discussion topic: Connection
Message posted on 13 Oct 2023 06:51 PM
Connection
Message posted on 13 Oct 2023 07:04 PM
Re: Connection
@Donnalouise52 wrote:
My sky mini box keeps losing connection.the engineer came out yesterday and replaced it. My broadband connection is good. Can anyone help
Reboot the mini as above.
Message posted on 13 Oct 2023 07:14 PM
Re: Connection
Hi thankyou for your reply. I've rebooted both boxes. My mini is new as they replaced it yesterday
Message posted on 13 Oct 2023 07:33 PM - last edited: 13 Oct 2023 07:34 PM
Re: Connection
Yes you have already said the mini was replaced.
However with any mini issue it's always best to reboot the main Q box first and then the mini.
If that didn't help did you carry out the Network reset on the mini?
Message posted on 13 Oct 2023 07:37 PM
Re: Connection
Yep done all that
Message posted on 13 Oct 2023 07:39 PM - last edited: 13 Oct 2023 07:39 PM
Re: Connection
Yep done all that
And the mini is still losing connection?
Did it work when the Engineer installed it?
Message posted on 13 Oct 2023 07:40 PM
Re: Connection
It work for about 12 hours
Message posted on 13 Oct 2023 07:42 PM
Re: Connection
Well @Donnalouise52
As I said if it still will not connect then it looks like you need a Q WiFi booster positioned midway between the Q box and your mini.
Who is your Broadband supplier?
Message posted on 13 Oct 2023 07:43 PM
Re: Connection
Talktalk
Message posted on 13 Oct 2023 07:46 PM
Re: Connectio
Talktalk
Ok so the mini will not connect directly to that so you need a Q booster to aid connection between the main Q box and the mini.
