9
This discussion topic has been answered Discussion topic: Issues with sound when downloading Brassic Season 5 Episode 3
This message was authored by: feesles
Is anyone else having issues wwith sound when downloading Brassic Season Episode 3. Sounds cuts off half way through then doesn't come back on. Rest of recordings and channels all have sound. We have tried deleting it and re-downloading it again but to no gain. Thanking you
This message was authored by: mrmole Answer
Re: Issues with sound when downloading Brassic Season 5 Episode 3
Download the HD version that is working fine!
This message was authored by: Ljeeeeeeezy
Yes same problem it's not good, I can't watch the rest until I know what's happened
I have the same issue. 29 mins in on Episode 3 and all sound goes
Avatar for feesles
Worked a treat! Thank you
This message was authored by: Gary1972
Now I'm getting there is a technical fault with this channel. Please try again later. How much am I paying for this!!!
This message was authored by: KevG52
I had the same issue. Just as Tommo was penciling the address from the notepad the sound went. I deleted it, tried again downloading a fresh. Problem persisted. Followed the suggestion of one of the guys above and changed the UHD to HD download again and that worked.
Avatar for feesles
Yeah we had to do the same. The rest seem to work in uhd though. Enjoy!
This message was authored by: Sparkland
Same issue with Episode 3 of Brassic in UHD - sound cuts out mid the scene where Tommo is at scribbling to work out the address for his son.
This message was authored by: NEIL40
We have same problem with UHd version sounds cuts out for the rest of the episode same palce as others mention. Deleting and re downloading didn't work i will try HD version even though I am paying more to watch an inferior quality version!
