Discussion topic: Connection to sky q box has a cross
This message was authored by: Jo-Anneparker
Connection to sky q box has a x
Re: Connection to sky q box has a cross
Hi @Jo-Anneparker
If this is the internet connection on your main Q box then try completely resetting the Internet connection.
