2
This discussion topic has been answered Discussion topic: Connection to broadband
This message was authored by: Benziesky
Sky Q not connecting to Broadband Have unplugged both box and Hub and still not connecting
Re: Connection to broadband
Hi @Benziesky
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Hi @Benziesky
Avatar for Benziesky
Thanks for your help 👍 up and running again 🤗
