Discussion topic: Connection to Sky q
This message was authored by: Adlad99
Connection to Sky q
Hi there, I rebooted my sky broadband hub, but now can’t reconnect Sky q box to internet. Any help Would be appreciated.  Thanks Adam
Adlad
Re: Connection to Sky q
Hi @Adlad99
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Avatar for Adlad99
@oldfella , thank you so much for taking the time to reply.  In the end I spoke with Sky Support.  I had to unplug the purple cable from the router, lay the router flat for five mins, then connect the Qbox then re connect the purple cable.   I had loads of software updates that are still uploading now, but up and running now.  Thanks again
Adlad
