Discussion topic: Connection problems
This message was authored by: PWRW
Connection problems
Getting msg everyday "there has been a problem finding your Sky Q box on the network" Main TV working but mini box loosing connection. Reset as instructed which sometimes works. What's the problem
Re: Connection problems
@PWRW when you say reset as insructed are you only rebooting the mini box or are you rebooting the main box first then the mini box ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: SiobhanW-
Same issue here. Having to reactivate connection to sky Q box but doesn't always work. If it doesn't, I have to restart the main box too.
Every time I turn on the mini box, I'm getting the same error message - "there has been a problem finding your Sky Q box on the network", but the main box has no connectivity issues reported and no internet issues either.
