Discussion topic: Connection problems
This message was authored by: JackieChatfield
Connection problems
Sky Q box and both mini boxes constantly dropping out of network and connection to each other. Today I've had to reboot every time I've switched the TV on. Broadband provider is BT and nothing else's drops out (computer, phones etc).
Re: Connection problems
The connection between Q boxes doesn't use you're broadband.  It uses its own network (5GHz channel 36) which may be actually clashing with your BT configuration.
Try changing your BT router's channel as high as possible to avoid conflicting.
Hi @JackieChatfield
Reboot the minis as above.
If the minis still does not connect reliably try a Network Reset on the minis. Start with the one nearest to the main Q box
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or previously connected mini).
Avatar for JackieChatfield
Thank you I will have a look at this.
Thank you @oldfella - ive tried all this and everything works accept one mini. Ill contact Sky directly.
