Discussion topic: Connection issues - sky q mini
This message was authored by: Allie9
Changed wifi/broadband from Sky to Virgin. Main sky Q box connects fine but my mini box connects for 10 secs then disconnects. Any ideas how to fix this?
Re: Connection issues - sky q mini
Hi @Allie9
With Sky broadband and the non fibre router the mini can connect to the router or Main Q box.
With Virgin broadband the mini must connect to the Main Q box.
Reboot the mini as above.
