Discussion topic: Connection issue between mini box and sky Q box
This message was authored by: Ashley85
Hi,
Keep getting issues with the connection between the sky mini boxes and the Sky Q box. Only recently started to happen. Broadband is all fine and no issues and signal strength and speed is really good. How do I sort this please?
Re: Connection issue between mini box and sky Q box
Who provides your broadband?  As the Q to Q connectivity may not use it and ironically may actually interfere.
@Ashley85 wrote:
Hi,
Hi @Ashley85
Reboot the mini as above.  Start with the mini nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
Avatar for Ashley85
Thanks for the reply. Vodafone supply my Broadband.
