4
This discussion topic has been answered Discussion topic: Controlling Sony tv connected to Sony soundbar with sky q remote
This message was authored by: Mrmoonster
Hi, this has suddenly stopped working after I rebooted my sky q box because the red recording light was on with no recording taking place. I have a Sony Bravia connected to a Sony soundbar via an optical cable, my sky q remote operated on/off on the tv and volume on the soundbar, but now it won't control the soundbar and I can't figure out how it was originally set up. Any help appreciated.
This message was authored by: nigea99 Answer
Re: Controlling Sony tv connected to Sony soundbar with sky q remote
@Mrmoonster wrote:
Hi thanks for reply, no it is just an optical cable from soundbar to tv and the sky q box is connected to the tv via a hdmi cable.
Many thanks. @Mrmoonster
Not sure why you would loose operation of the Sound bar but not the TV (or even both really)
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
After re-pairing with your TV you should get an option to pair with your Sound bar
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
hi @Mrmoonster
I will reply here rather the other discussion you posted on.
Can I ask is your Sound Bar connected to your TV via an HDMI cable even though you may be using an optical cable from SKY Q to listen to SKY
Avatar for Mrmoonster
Well that's cracked it! Thanks all.
