Discussion topic: Connection isdues
Message posted on 04 Aug 2024 10:46 PM
Connection isdues
So we took our sky q box to the van tried connecting to the campsites WiFi which was unsuccessful. Since being home just noticed it's connected to the campsites WiFi which is impossible as it's 2hrs away. Tried resetting and reconnecting to our router but it still keeps connecting to the campsites WiFi name. Any suggestions on how we can rectify this it's driving us crazy. Thanks
Message posted on 05 Aug 2024 10:17 AM - last edited: 05 Aug 2024 10:19 AM
Re: Connection isdues
As you are were in breach of the terms and conditions of your Sky contract by doing so, this forum is not an ideal place to seek advice.
In principle, a network reset or full box reset should resolve the issue.
Message posted on 05 Aug 2024 12:44 PM
We have tried the reset of the router and reset of network but does nothing keeps reverting back. How do you do a full box reset and will it wipe everything we have saved ?
Message posted on 05 Aug 2024 12:48 PM
Unfortunately we did use it elsewhere , if we were to contact sky if we cannot resolve the issue what's the worst they could do woukd they just cancel it ?
Message posted on 05 Aug 2024 01:20 PM
Just carry out a Network reset on the Q box @Mtemple7
Message posted on 05 Aug 2024 02:08 PM
We have already tried this several times we have a sky router so pressed the WPS button. When it's connecting it does not even bring up our sky network and just goes to the wrong network automatically.Our mobiles are connected to wifi fine so god knows!!
