31 Jul 2024 01:30 PM
In trying to connect my mini box to the sky q box,I've rebooted the q box but it didn't work,it's asking if I have a active broadband which I do,can't press yes or no and comes up with a error mr106,can anyone help
31 Jul 2024 01:32 PM - last edited: 31 Jul 2024 01:34 PM
Hi @Sarah672
Reboot the mini as above.
edit
Note if you have to press the standby button on the Q box to switch it then
31 Jul 2024 01:41 PM
I've tried that
31 Jul 2024 01:55 PM
Posted by a Superuser, not a Sky employee. Find out more31 Jul 2024 02:10 PM
I get to where it asks you to press the home button to get started,it then asks have you got an active broadband signal which I have,it asks me to press yes or no but it won't let me press either
31 Jul 2024 02:16 PM
Hi @Sarah672
On your mini remote press and hold 7 & 9 on the remote until it's led flashes four times.
This will set the remote to infrared mode which will work all boxes in line of site.
Reboot the mini again and then see if the remote will let you press yes
Remember to point the remote at the mini .
If you can get the mini working then repair the remote by pressing 1 & 3 and following onscreen instructions.
31 Jul 2024 02:33 PM
Thank you so much,that worked
