Discussion topic: Connecting to sky Q when I move my tv
This message was authored by Richo2511 This message was authored by: Richo2511
I want to move my tv and main sky q box but don't know if it has to be connected to a satellite dish
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Connecting to sky Q when I move my tv
Yes, it does.
It will 'work' for a while (days) without a satellite signal for recordings and apps but will eventually stop completely.
You can buy extension cables for the satellite leads or pay Sky around £65 to move the wall inputs (if viable).
I am just another Sky customer and my views are my own
Hi @Richo2511
Provided the new position is on an outside wall and in a reasonable distance to the satellite dish then Sky then you could ask Sky if they will re-locate or install new cables.
Failing that as already noted you can use readily available satellite extension cables.
