Discussion topic: Connecting to new tv
I've recently bought a new tv , and after connecting my Sky Q box I found my Home page won't load but I can play my tv channels through Sky?
Re: Connecting to new tv
Hi @Anonymous
Looks  like you have lost internet connection on your Q box.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
