Discussion topic: Connecting a DVD player
This message was authored by: Henry+the+eigth
Hi all excuse me if I appear a little stupid but since I bought my Samsung Smart TV I have no idea how to navigate between the Samsung TV stuff and my Sky Q, and cannot now find how to connect my DVD so that I can actually see a picture? I used to be able to press a button get a drop down list change to the channel for playing a DVD and then back again. Now? I have no [Removed] idea where I am?! I have the HDMIs set correctly but when I press the button on the top right of my sky remote I get loads of stuff on a sor t of taskbar along the bottom of the screen mixed up with Samsung stuff?!! Help please?! Many thanks. H🙄
Moderated to remove language and moved to TV discussion.
Re: Connecting a DVD player
hi @Henry+the+eigth
I am sorry I am not familiar with Samsung TVs
It is quite possible that the SKY remote's limited function of  normally just selecting an HDMI input is not suitable, although it may possibly be able to do this by changing some settings on your TVs menus.
You will need to lookup the help for your TV and use the TV's own remote to change any settings & it may always be necessary to use the TV's own remote to select your DVD player
You may also be able to set the TV & DVD players 'CEC' control to on which would mean playing a dvd would automatically switch the TV - although note the Player & TV may note refer to CEC but other names - my Panasonic  TVs and players call it Viera Link (but that is Panasonic's own name)
Avatar for Henry+the+eigth
Level 4 icon
Hi  Nige sorry for the delay in my reply thanks so much for your help and for taking the time to help, will let you know if I succeed. Take care. H😊
