Discussion topic: Connecting Focal analogue speakers to LG TV
Message posted on 22 May 2025 04:36 PM
I have a new LG OLED 65 inch TV.
I have a pair of high end analogue Focal speakers
I attached a PROZOR 192Khz DAC convertor by Optical lead from TV optical output and thence by headphone jack to the Focal speakers with RCA coax connectors
The Sound output works but I have discovered that the optical out has no volume control ability and therefore the sky remote cannot control the volume, even though it is successfully paired with the TV. Any suggestions as to how to connect the TV output to the Focal speakers and which also allows volume control by the Sky remote?
Message posted on 22 May 2025 04:52 PM
Re: Connecting Focal analogue speakers to LG TV
hi @MIKEW-UK
I don't know Focal Speakers specifically but I don't suspect they lead themselves to the sort of setup you are trying.
I suspect they are more suitable to a more conventional connection via an amplifier that has speaker connections
To get decent sound from you rspeakers you probably also need to know the power handling capabilities of the speakers and check that any amp is suitable for driving them
Message posted on 22 May 2025 05:01 PM
Thanks for your rapid response
The Focal speakers were attached to the headphone socket of a prior Psnsonic T and worked flawlessly. They also function perfectly with the new LG T connected using the optical out to input of a DAC convertor and then
through the headphone out socket of the convertor to the speakers with RCA coax connectors. The issue is that optical out signal is steady and does not permit volume control through the TV remote or Sky remote. I wonder if HDMI out to a convertor and then to the speakers would permit volume control by remote?
Message posted on 22 May 2025 05:06 PM
hi @MIKEW-UK
Such a converter is likely to give the same results as your optical. DAC converter.
I have not done any research on any such converters but have you looked specifically for optical or HDMI coverters specifically for Headphones ?
Message posted on 22 May 2025 07:45 PM
I shall research further. I will either have to find a Dac optical to analogue convertor with a volume control on the ouput built in ,
or a HDMI to analogue convertor if such a thing exists. Thanks again.
Message posted on 23 May 2025 04:36 PM
All sorted.
Purchased from Amazon PROZOR HDMI ARC Audio Extractor 5.1CH – HDMI ARC to Optical SPDIF RCA L/R 3.5mm 2.0CH Audio Converter Supports 192kHz DAC, Dolby/DTS for ARC TVs, Home Cinema & Sound Systems.
Tv HDMI ARC cable to Prozor HDMI, headphone out to Focal active speakers. Sky remote controls all functions including volume through speakers. Thanks
