Discussion topic: Connected a new soundbar but tv keeps losing internet and mini boxes don’t work
This message was authored by: ColinT1
I replaced my old soundbar yesterday but since then for some reason my main tv keeps saying it's not connected to the internet ( in sky home page) and my two mini boxes no longer work?
all I did was unplug old hdmi and optical cable and plug in new hdmi into tv ARC port.
Have had to re type router password several times on tv as it keeps dropping out, and tried same on mini boxes but they don't connect.
feel like going back to my 10 year old soundbar ☹️
Re: Connected a new soundbar but tv keeps losing internet and mini boxes don’t work
Hi @ColinT1
When you your TV will not connect to the internet I assume you mean the main Q box.
Avatar for ColinT1
Hi, thanks for your reply but I have tried that already but didn't resolve problems. It's a 3rd party router with no reset button so had to unplug and re type router password but just keeps dropping out each time. Unplugged Sky mini boxes too but don't respond to remote now, it's just getting worse!
This message was authored by: Jmorr
I have this same problem at a Sky mini. New Samsung soundbar with wireless sub and surround speakers and the Sky mini at that tv can no longer see the Sky Q and/or internet. Did you get any useful tips?
it seems to me that the Sky mini has poor EMC protection as with soundbar off all is well.
More likely that the new soundbar is using the same frequency as the Q mesh.  Are there any settings to change the channel that the soundbar uses?
I did think of this. I have a WiFi analyser that doesn't show-up any additional channel use at ch36 for the Q mesh.
Hi @ColinT1 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
Have done that multiple times.
Wonder if the new one has some inteference leak. Worth trying the old one again just to test.
edit: oh sorry that was to the original post. This one is wireless? Will be using 2.4GHz spectrum and won't show up on a wifi analyser as it's not wifi. Can you use ethernet or powerlines for the mini?
