This discussion topic has been answered Discussion topic: Connect sky Q multiroom to new wifi
Message posted on 09 May 2024 11:30 AM
Hi folks, hoping for some help with our Q setup following broadband provider change.
We had SkyQ multiroom installed about a year ago. The engineer placed two Sky Routers to bounce the signal between Q boxes. One of these boxes was connected via ethernet to our broadband router; the other doesn't have an ethernet port.
We have now changed to fibre internet and the new fibre router is in a different place so cannot connect directly to the sky router. I have tried reversing the two sky routers so the one with the ethernet socket plugs in to the new fibre router, but they do not connect to the internet.
A similar (but not identical) question was asked here: Changing Wifi Network - Mini Box not connecting - Page 2 | Sky Community but the answers are not visible.
Thanks in advance
Message posted on 09 May 2024 11:33 AM - last edited: 09 May 2024 11:42 AM
Thanks in advance
Hi @Repton86
Try the following procedure.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On  3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band which I'm sure you are aware.
When the main Q box is back up and running reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini  box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
As soon as the mini is back up and running try another Network Reset on the mini.
Thanks in advance
Hi @Repton86
Message posted on 09 May 2024 11:38 AM
							Re: Connect sky Q multiroom to new wifi
Thank you @oldfella, I will try your suggestion.
Message posted on 12 May 2024 03:05 PM
I have tried @oldfella's suggestion and no joy.
The mini box cannot connect directly to the main box as it is too far away. The main box is now connected to our new 3rd party router. The mini box doesn't give the option to connect directly to our new network - instead it insists on connecting only to Sky Q products (the main box or the Sky Q routers which the engineer fitted when Sky Q installed).
I have been able to connect one of these routers to something (presumably the main box - impossible to tell what it is connected to but all three lights green).
At this point I was able to get the mini box to get to step 4 of the (very slow) connection process only for it to give up.
I have not been able to connect the second router.
Message posted on 12 May 2024 03:10 PM
Nevermind, I retried what I have tried the first time (reversing the sky Q routers) and now it's working fine.
Thanks for your input.
Message posted on 12 May 2024 03:24 PM
It's difficult to know what exactly the 2 extra boxes are. Are they similar or completely different?
I'm guessing at least 1 is a booster and just sounds like the distance between main and mini is too great. To persist with this setup it would seem like you still need both "boosters" but sounds like at least 1 isn't co-operating. I would try to play around with the placement of the booster that seems to be working ( if possible). I presume moving it closer to mini but this is into an area of total trial and error.
For anyone who has read any of my posts, they will know I usually mention powerline adaptors. Again physical distance between boxes could be an issue but something to look into if there is no progress with the boosters.
