Discussion topic: Channle 4 is not working
This message was authored by: Helen171
Recently had scaffolding taken down. All other channels working.
Channel 4 plus 1 is working. Channel 4 is not and the message says its a satellite problem. Have reset the box but that didn't help.
Re: Channle 4 is not working
@Helen171
Perhaps workmen knocked the dish?
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
