Discussion topic: Channels
This message was authored by: Taj
Channels
Hi, the HDMI cable was disconnected, however when I reconnected the cable back I can't seem to get access to any of the sky channels. I bought a brand new HDMI cable still no luck. The standard TV channels seems to be working as normal. Any suggestions please 🙏
Re: Channels
Hi @Taj
Are you sure that your television set is switched to the correct HDMI input for the Q box?
It would appear that you are using the Television terrestrial aerial tuner and not the Sky Q box HDMI input
Avatar for Taj
Level 0 icon
Re: Channels
Hi, the television set is switched to the correct HDMI input for the Q......no luck.
This message was authored by: ThePope27
Re: Channels
@Taj
Try selecting the correct HDMI port and then  rebooting the box while the correct hdmi port is selected
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
