Discussion topic: Channels not working
Message posted on 17 Jan 2024 10:36 PM
Most of the channels aren't working on my sky, it has a message saying the channel is currently affected by a problem with your satellite signal. I can't get BBC or ITV or channel 5, can get BBC2, C4 etc
Message posted on 17 Jan 2024 11:08 PM
Re: Channels not working
https://www.sky.com/help/articles/sky-tv-no-satellite-signal
you may need your dish alignment checked
Message posted on 18 Jan 2024 04:43 AM
@shirleydcrouch
Firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. If your dish is out of alignment, it’s not something that will necessarily be visible to the naked eye. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
