4
This discussion topic has been answered Discussion topic: Channels have gone missing
This message was authored by: BryanLorigan
When I turned on Sky on Satyrday after a few days away I found that the majority of channels were now not available.
I still  have BBC 1-4, ITV 4 (but not ITV 1-3), Sky Nature and a number of other random channels..
I have done all the checks as recommended by the bot - checked the connections, no bad weather, no obstruction of the dish, turned the box off and on again, etc.
For the channels that have gone missing I get the message "This channels is currently affected by a problem with your satellite signal."  When I go into Settings / Status I see that the satellite signal is good.
Any suggestions to solve this problem?
This message was authored by: oj01 Answer
Re: Channels have gone missing
@BryanLorigan wrote:
I see that your lengthy response was posted at the same time as my query.........am I communicating with an AI bot?
In my query I said that I had checked the connections so I am surprised that you mention this as something that I should check.
I said that the signal strength was "good" - is that consistent with your suggestion that the dish is misaligned?
The signal showing as "good" is a bit of a red herring with Sky Q as it only reports on the status of a default transponder not the channel that you are currently tuned to.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
@BryanLorigan
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for BryanLorigan
@BryanLorigan
No. I'm just quick 😂 This scenario is very common so my response is saved as a template.
