Discussion topic: Channel 5
Message posted on 15 Feb 2024 07:55 PM
Channel 5
Channel 5 and other channel 5 associated channels just stopped working yesterday on sky q. Why is that because nothing has changed i.e. equipment, dish alignment?
Message posted on 15 Feb 2024 07:59 PM
Re: Channel 5
@traceyswife Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 15 Feb 2024 08:02 PM - last edited: 15 Feb 2024 08:03 PM
Re: Channel 5
@traceyswife wrote:Channel 5 and other channel 5 associated channels just stopped working yesterday on sky q. Why is that because nothing has changed i.e. equipment, dish alignment?
Working fine for me. Did a reboot sort it for you?
Message posted on 15 Feb 2024 10:33 PM
Re: Channel 5
- Have rebooted several times without success. On further investigation there are many channels that display tge following message 'this channel is currently affected by a problem with your satellite signal'. The 'help' suggestions on themessage page haven't helped either. Have turned box off at mains and still same message comes up. Have there been any updates that could have caused this to happen? Waiting for sky support to give advice too.
Message posted on 15 Feb 2024 11:16 PM
Re: Channel 5
This sounds more like your dish has been knocked out of alignment, possibly by the recent storms. If this is your dish, you'll need to contact Sky & request an engineer (or you could contact a local independent which might be quicker but cost). If this is a shared dish, you'll need to contact your building management.
Message posted on 13 Jul 2024 01:45 AM
Re: Channel 5
I have also lost my 5 channel s since yesterday?
I have a sky q tv. These do not have a dish so it has nothing to do with dish alignment
Message posted on 13 Jul 2024 05:34 AM
Re: Channel 5
Sky Q boxes are reliant on a satellite dish to work, either your own dish on a communal dish.
Message posted on 13 Jul 2024 11:06 AM
Re: Channel 5
Sorry meant sky glass however it has resolved itself this morning.
