Discussion topic: Channel 4 app not on mini box
This message was authored by: reddude
Hi
the Channel 4 app has appeared on my main Sky Q box and 2 of my Sky mini boxes but still has not appeared on my 3rd box.
I've tried refreshing the apps and restarting the mini box but the app has still not appeared.
Any help would be appreciated
Kind  regards
Re: Channel 4 app not on mini box
@reddude wrote:
Hi
the Channel 4 app has appeared on my main Sky Q box and 2 of my Sky mini boxes but still has not appeared on my 3rd box. I've tried refreshing the apps and restarting the mini box but the app has still not appeared.
Kind  regards
Hi @reddude
First try rebooting your Main Q box and when this is completly back up and running reboot the problem mini.
Avatar for reddude
Level 3 icon
Hi
Sorry for delayed response.
It's been a busy few days.
Unfortunately this did not work.
I'm think it's probably because this box is connected via ethernet while the other boxes are connected via WiFi network.
It's something I will have to try at a later date as the location is awkward.
Thanks for your help
Regards
This message was authored by: Steve208
Hi,
Currently have the same problem with the same setup, 1 main Q box, 3 mini boxes which 2 have the app but 1 does not.
Did you manage to get this working?
Avatar for reddude
Level 3 icon
Hi
Yeah after a few weeks then channel 4 app just appeared on my mini box.  It just eventually updated itself.
Awesome, thanks for your reply!
Avatar for reddude
Level 3 icon
No worries
