Discussion topic: Channel 4 app not offered on Sky Q
Message posted on 17 Feb 2024 10:18 PM
Hi, the Channel 4 App is not listed in the apps on my Sky Q box. I only have the main box. Do I need to update the apps?
Message posted on 17 Feb 2024 10:22 PM
Re: Channel 4 app not offered on Sky Q
Hi @apemyr
First thing to do is a Software Update to make sure the box is on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software.
Then try refreshing the Apps in the Hidden menu.
Select Apps
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
