Discussion topic: Changed broadband minu box issues
This message was authored by: Reprhi
Hello
Ive changed my internet provider changed all details on the main sky Q box it says connected then dips in & out of connection meaning I'm struggling to set up the mini box to link with it also.
Is this a sky issue or my broadband?
Re: Changed broadband minu box issues
@Reprhi wrote:
Hello
Hi @Reprhi
Your photos have been removed as they show you're personal Network details.
Reference your issue try completely resetting your main Q box Network connection.
Avatar for Reprhi
done all that & still getting connected / not connected on screen with new router
so thinking it must be the new broadband
ringing provider
ringing provider
Hi @Reprhi
How far is your router from your main Q box?
Edit
is the connection issue your main Q box or your mini??
Avatar for Reprhi
Hello a floor level & a room across
i thought it was the mini box but it's the main box won't connect / disconnecting  from internet that's why mini box won't connect
