1
This discussion topic has been answered Discussion topic: Changed Service Provider - Multi Room not Connecting
This message was authored by: addicksteve
Have just changed my broadband service to plusnet. Sky Q box working fine but multiroom not connecting? Any ideas ??
Re: Changed Service Provider - Multi Room not Connecting
Hi @addicksteve
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
Hi @addicksteve
