Discussion topic: Change to sky essentials with a Q box
This message was authored by: PF10
Message posted on 05 Jun 2025 11:52 AM
When switching to Sky essentials with a q box do you loose all sky channels?
Find out more
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Please note: I am just a sky customer not a employee - posts from sky employees (aka community team) are clearly marked as suchmy setup: Samsung 5 series 32inc tv | sky +hd box | variety, SKY & TNT sports,sky cinema | Netflix and prime video Please note: I only provide help on the main forums and not via PM ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ if this post has helped please give it a like ~ if this post has solved your question/query please mark it as the answer in order to help others
Message posted on 05 Jun 2025 11:55 AM
Re: Change to sky essentials with a Q box
@PF10 Yes apart from the free to air channels
Find out more
Message posted on 05 Jun 2025 12:08 PM
@PF10 Also note that Essentials on SKY Q is not the same as Essential TV on SKY Stream (that includes SKY atlantic & Netflix) which is a bad choice of a similar name
