Discussion topic: Change package
Message posted on 27 Jun 2026 01:24 PM
Change package
Message posted on 27 Jun 2026 01:28 PM
Re: Change package
Add or reduce?
Cancel PART of your TV package:
You need to contact Sky giving 31 days notice. If you have 'in contract' discounts you may not be able to remove them, because the discounts were provided on the understanding you’d be paying that discounted price for the full period. Also make sure cancellation of a certain add-on doesn’t affect another discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling using the number that should appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
Re: Change package
@Kathsephton wrote:
Can I change my package on line? Or do I have to call ?
You can normally upgrade on line, with downgrades needing a phonecall.
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
