Discussion topic: Chanel affected by a technical problem
This message was authored by: Matt0604
Message posted on 03 May 2026 02:09 PM
Constant blue screen and 'this channel is affected by a technical problem' for lots of channels on both the main box and the multi room box.
also have to keep hard resetting the box as it freezes or crashes.
does anyone have any suggestions?
Find out more
Message posted on 03 May 2026 02:13 PM
Re: Chanel affected by a technical problem
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
