Discussion topic: Chanel affected by a technical problem
This message was authored by: Matt0604
Constant blue screen and 'this channel is affected by a technical problem' for lots of channels on both the main box and the multi room box.
also have to keep hard resetting the box as it freezes or crashes.
does anyone have any suggestions?
Re: Chanel affected by a technical problem
@Matt0604
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
