Discussion topic: Cant select anything with my sky q remote
This message was authored by: Millsey
I can't select any programmes using my sky q remote, I have changed the batteries, turned off sky q, but nothing is working
Re: Cant select anything with my sky q remote
Hi @Millsey
Avatar for Millsey
Thanks have pushed 1 & 3 and it's come up with toys sky q remote is paired, gives me the option to continue or skip step but I can't select anything
Avatar for Millsey
Have also tried another 2 sky q remotes on the sky q box but the select button doesn't work either
