Discussion topic: Cant connect sky q to wifi
This message was authored by: CarlDutton
Hi, i lost my internet connection last night and now i cannot connect my sky q box to my wifi. Ive reset my skyq box and my router several times and still says cannot connect. All other devices in the house still connect with no problems. Any help would be appreciated. Cheers Carl
Re: Cant connect sky q to wifi
Hi @CarlDutton
Assume this is your main Q box.
Have you tried a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for CarlDutton
I originally reset the network today but this option no longer appears in the menu
Hi @CarlDutton
You still have choices in Network to Connect to WiFi.
Who is your Broadband supplier?
Hi @oldfella im with sky broadband. I have the option to connect to sky broadband wifi, then press and hold the wps button on router. This just searches for about 2 minutes then says cant connect. The wps button flashes red on the router
OK @CarlDutton
Is the WPS led flashing on the Main Q box before you press the WPS button on your router?
Also are you sure that you are pressing the Sky router WPS and not the reset button?
@oldfella, yes the sky qbox is flashing before i press the router wps (button with 2 curved arrows on). Im sure the problem must be with the sky q box
