Discussion topic: Canny record
Message posted on 27 May 2024 07:50 PM
Canny record
I cannot record
Message posted on 27 May 2024 07:55 PM
Re: Canny record
Error messages?
Message posted on 27 May 2024 08:04 PM
Re: Canny record
@Deidre1 wrote:
I cannot record
Hi @Deidre1
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 27 May 2024 08:06 PM
Re: Canny record
@Deidre1 wrote:
I cannot record
@Deidre1 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
