Discussion topic: Cannot get sky box to switch on
This message was authored by: Mark2810
Sky box will not switch on
Re: Cannot get sky box to switch on
Try the Sky Q recovery procedure from power off as described in step 2 here;
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/sky-q-box-wont-turn-on...
Hi @Mark2810
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
