Discussion topic: Sky Q box will not connect to Wi-Fi .other devices can connect to the Wi-Fi .
Message posted on 21 Jul 2024 06:15 PM
No matter what I try my sky Q box will not connect to the Wi-Fi all my other devices connect ok
there is nothing new . It just seems to have lost connection and will not reconnect
Message posted on 21 Jul 2024 08:17 PM
Re: Sky Q box will not connect to Wi-Fi .other devices can connect to the Wi-Fi .
@Happy2 who is your broadband provider ? and what have you tried already ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 Jul 2024 08:38 PM
Hi @Happy2
