Discussion topic: Cannot connect to skyq box
This message was authored by: Magliano
Message posted on 31 Jul 2024 06:30 PM
Cannot get beyond step 2 of 4
Find out more
Message posted on 31 Jul 2024 06:33 PM
Re: Cannot connect to skyq box
Hi @Magliano
On your Q remote press and hold 7 & 9 on the remote until it's led flashes four times.
This will set the remote to infrared mode which will work all boxes in line of site.
Reboot the Q box again and then see if the remote will get past step 1.
Remember to point the remote at the Q box.
If you can get the Q box working then repair the remote by pressing 1 & 3 and following onscreen instructions.
