Discussion topic: Cancel recording
Message posted on 29 Mar 2023 05:34 PM
Cancel recording
I have a recording in continue it has been deleted but it remains there and cannot get rid of it any ideas
Message posted on 29 Mar 2023 05:37 PM
Re: Cancel recording
Hi @Lynn+x I never use Continue, much better to use Most Recent.
Message posted on 29 Mar 2023 05:49 PM
@Lynn+x this may or may not work but try deleting the programme from the deleted section
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
hi @Lynn+x
The Continue section is not actual recordings but just a set of links.
We tend to advise people to ignore the Continue section unless you know for definite it it the recording you want and at the corect point
I find the continue section can point to recordings I have already finished watching and deleted or sometimes points to the 'next' episode when I haven;t completely finished the previous episode.
If you want to try to remove an entry I believe - but not sure - if it is pointing to a recording you have watched (& not as I mention the one you have not started) then if you delete the recording from the 'Most recent' section and then go to Recordings - Manage - Deleted and selecte the recording & Select Delete forever this should remove th eentry from the Continue section
