Discussion topic: Can’t view sky documents
This message was authored by: Trevor2
Can't view sky documentaries
Re: Can’t view sky documents
hi @Trevor2
If this is on demand/catch up content & you don't have the HD add on may I suggest you change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
