Discussion topic: Can’t use sky remote away from tv have to go right up to tv to work and then sometimes it won’t work
This message was authored by: Lisa259
Put new batteries in remote paired it again but still not working properly.  I have to walk up to tv for it to work and then it is not always doing it.  Just tried to press for channels and the sky channel was jumping back and forth and wouldn't go to where I wanted it to
Re: Can’t use sky remote away from tv have to go right up to tv to work and then sometimes it won’t
Hi @Lisa259
First reboot your Q box.
Then,
