26
This discussion topic has been answered Discussion topic: Can't get ITV
This message was authored by: Cassie59
Can't get ITV
For some reason I can no longer get ITV, I have SkyQ, based in Ireland but was always able to add the channel by going into settings etc but it has suddenly stopped.
This message was authored by: xenon81 Answer
Re: Can't get ITV
Most ITV channels changed transponders recently, viewers in Ireland will need to retune.
Delete the old channels first then manually tune in to:
ITV1/UTV - 11386 V 27.5 2/3 DVB-S2 8PSK
ITV2 - 11386 H 27.5 2/3 DVB-S2 8PSK
ITV3 - 11344 H 27.5 2/3 DVB-S2 8PSK
ITV4 - 11386 V 27.5 2/3 DVB-S2 8PSK
ITVBe - 11386 V 27.5 2/3 DVB-S2 8PSK
Re: Can't get ITV
Avatar for Cassie59
Re: Can't get ITV
Aw brilliant thank you so much
This message was authored by: Niall73
Re: Can't get ITV
Thanks for the codes just wondering if  there is a code for the plus 1 ITV station
Re: Can't get ITV
@Niall73
Please sse this link
https://www.lyngsat.com/Astra-2E-2F-2G.html
Don't forget to delete existing manual  entries first before searching again
This message was authored by: JamesCal
Re: Can't get ITV
Thanks - was baffled. Works a treat !
This message was authored by: Kevdev19
Re: Can't get ITV
Thank you done the trick
This message was authored by: Suzy721
Re: Can't get ITV
Trying to do this but cannot find 'services'on remote???
Re: Can't get ITV
hi @Suzy721
Services is an option on older SJY +/HD boxes
If you have SKY Q then manual Tuning is in
Home - Settings  - Manual Tuning
This message was authored by: JH33
Re: Can't get ITV
These codes do not work. I have Sky Q  - no stations found message
Re: Can't get ITV
@JH33  you must make sure you delete old entries before scanning
The frequencies in the link I gave earlier are current - edit : which match those posted in the Answer
Re: Can't get ITV
thanks but I did that - still no stations found. It used to work. I had tuned in ITV 1, ITV 3 etc. I deleted all of them and tried all the codes posted - but nothing works.
Re: Can't get ITV
@JH33  Make sure all the paramaters are correct - it easy to miss one especially the 8PSK
Re: Can't get ITV
I really have done it very carefully several times. Giving up now. Thanks for replying
This message was authored by: maranello
Re: Can't get ITV
Exact same problem here too with sky q box all itv not working. Same response when trying to manually tune in again.
