Discussion topic: Sky Sports F1 very poor signal
Message posted on 25 May 2025 12:42 PM
All weekend the F1 channel has been freezing and dropping out totally. I've rebooted the Q box and the router to no effect.
Message posted on 25 May 2025 12:43 PM
Re: Sky Sports F1 very poor signal
Other channels working perfectly.
Message posted on 25 May 2025 12:44 PM
Likely to be your dish alignment.
Message posted on 25 May 2025 12:45 PM
hi @WeeMann
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
If you normally watch the UHD channel then it is probably worth trying watching the HD version (further down the channel list) until your problem is sorted
Message posted on 25 May 2025 12:52 PM
I've been googling and that seems to be the popular opinion.
Looks like I need to book an engineer, none of that has worked. Thanks.
Message posted on 25 May 2025 01:26 PM
@WeeMann Just a though you dont have a wireless dect phone anywhere near your Q box do you. As the signal from the phone has been known to cause problems on the F1 channel before
Message posted on 25 May 2025 02:26 PM
No signal at all here. Trying to watch f1 and there's nothing at all. Blank screen. Won't even slow me to turn the box over
