Discussion topic: Can not adjust volume
This message was authored by: Nicola217
The remote works for all other functions but not the volume
Re: Can not adjust volume
Hi @Nicola217
Looks like your remote is not correctly paired to your Television.
Avatar for Nicola217
Level 0 icon
Thank you that has worked
