Discussion topic: Sky q min box keeps freezing and losing connection
Message posted on 03 Jan 2026 09:37 AM
One of my Skye Q mini boxes keeps freezing losing connection and keep trying to reconnect to the other boxes It's been doing it for the last five days
Message posted on 03 Jan 2026 11:06 AM
Re: Sky q min box keeps freezing and losing connection
Hi @Lee330
Have you tried swapping the problem mini with one of the other minis?
Also try completely resetting the connections.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
