7
This discussion topic has been answered Discussion topic: Calling you to have help with Tv
This message was authored by: catherinefisher
I have tried to ring you up to see if you could come out and see to our mini sky q box and TV but I can't call you
Re: Calling you to have help with Tv
@catherinefisher
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
What Sky Q issue do you have?
Whats happening when you call Sky?
Hi @catherinefisher
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
@catherinefisher
Avatar for catherinefisher
Whenever we turn the mini sky q box off to try and get rid of a crackling sound on the tv it doesn't work
When we're having trouble with the mini sky q box we don't have trouble with the main sky q box
@catherinefisher
Do you mean the mini box doesn't switch back on again?
Is the crackling noise on the TV when the mini box is unconnected- ie; viewing on Freeview?
The crackling sound is on the TV and mini sky q box but not on the main sky q box but when the mini sky q box is turned off the TV says no signal
@catherinefisher
I think the likelihood is the sound issue is on that particular TV not the mini box.
Of course it will as the feed from the mini box has been switched off. Change the source on the TV and try to view a Freeview channel.
Answered - Go to Answer
