Discussion topic: CATCHUP TV dont have required subscription to download the programme
This message was authored by: Titch01
dont have required subscription to download the programme ?
Avatar for Titch01
Level 0 icon
Customer Support
Telephone number for customer support
Re: CATCHUP TV dont have required subscription to download the programme
Some catchup services require the HD subscription.
Do you have HD sub?  What channels are you having issue with?
Re: Customer Support
@Titch01 Is the issue something we can help with and save you a call?
These are the current methods for contacting Sky…
▪️call by dialling 150 (free) from either a Sky Talk landline or a Sky mobile.
Calls to Sky will start automated which may offer you the online help route (see below) or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
▪️online help via this link
https://www.sky.com/help
▪️ Sky Assistant is also available at the top of sky.com/help for most service issues and gives you 24/7 help and a quick response. It will provide you with multiple choice options based on your problem and will provide troubleshooting steps to fix any service issues.
▪️Social Media You can also get in touch with Sky via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
This message was authored by: popacatapetal
There are loads of posts about this issue dating from 2023 but it,s still happening .
it has now started happening to me with old episodes of New Tricks series 7 for example,.
The fix in my case involves selecting U&Drama in epg to give a live feed   can be any program on U&Drama.
Then go to download options and select.Downloads ok and will download following episode when you you start viewing initial download.
Also applies to Alibi.
Fix not permanent but can be easily reimplemented.
