Discussion topic: Buying additional mini box
Message posted on 08 Mar 2024 04:27 PM
Message posted on 08 Mar 2024 04:30 PM - last edited: 08 Mar 2024 04:31 PM
Re: Buying additional mini box
@Forest1889 wrote:
Is there a limit to the number of Sky Q mini boxes you can have
@Forest1889
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
