Discussion topic: Buttons 1, 2, 3, 4 do not work
Message posted on 23 May 2023 07:14 PM
All other buttons do.
Message posted on 23 May 2023 07:24 PM
Re: Buttons 1, 2, 3, 4 do not work
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Is this doesn't solve your issue
Check out the following link.
Click still need help and then click get in touch after ticking the box that you have tried online help. This will lead you to a form for free remote replacement.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
