Discussion topic: Builders need to move sky dish
This message was authored by: Gillian91
I'm having a extension built and the wall the sky dish is on is being taken down
Re: Builders need to move sky dish
Then you won't be able to receive any Sky TV service if there's nowhere to relocate your dish to.
@Gillian91
As @Angel_Aka indicates, Q requires a periodic subscription refresh signal sent over the satellite and so won't function even for on-demand content or Recording playback without a dish feed.
You could potentially use Sky Go, but you'd need to unplug the main Q box from its mains connection otherwise the app tries to use dish reception for live channels.
@Gillian91
Hopefully you mean the builders want the dish moving, not that they intend to move it themselves?
Sky will carry out the moving of the dish provided there is a suitable alternative place for it. Call Sky to arrange who charge in the region of £65 for this service. You could get a quote from a local independent satellite engineer but make sure they move it to a position that a Sky engineer can easily access in the event of a dish issue.
